1954 Johnson 10hp fuel pump conversion
Yesterday at 10:31pm Quote
I'm stumped. I converted this Johnson for an old friend and shipped it to AZ from MN. I used the technique shown in http://outboard-boat-motor-repair.com/Johnson/Pressureized Fuel Tanks.htm .
I've done this before on my 7.5HP and 5.5hp. I used the Mikuni pump as shown in the article.
The problem is the motor runs out of gas. It does not appear that the pump is working correctly. The lines from the tank have been checked. The vacuum line from the intake manifold cover is secure and tight. He even opened up my conversion and made sure the plug is secure in the crankcase hole.
He started the motor and disconnected the hose to the vacuum port on the pump.He really couldn't feel any vacuum. Just positive pressure. Neither of us know how it's supposed to feel.
Essentially he has redone the conversion and re-checked everything I had done.
The question is whether the brand new pump is somehow defective or are you supposed to feel more of the vacuum pulsations at the end of the line that connects to the vacuum port on the pump. As you can imagine my "gift" has turned into a mess. When I tested the motor beforehand it ran dry, but I tightened my line from the intake manifold and it seemed to work great after that.
Is there a way to check if the pump is working correctly? or if the conversion is done correctly?
Thanks for any help.
Back to top
Back to top
