Gas in raw water pump oil reservoir
PAUL22
Hi all,
(merc 454 7.4l 1996 of809461 with bravo iii)
last yr. I serviced the oil reservoir in the raw water pump , and found some gas mixed w/ the oil. (i have the mechanical fuel pump that sits on top of the raw water pump). There was never any gas in the clear tube to the carb. I changed the mechanical fuel pump.
This year, i serviced the raw water pump, and again found gas mixed w/oil! The clear tube does't have any gas going to the carb.
It appers to be an enginering design flaw. Can i do anything to prvent this problem?
Tia
paul22
p.s. Thanks to all the fine people who have posted on this site, i have learned lots and fixed several issues over the years. (hydrolock, bellows ,gimball bearing,allignment,u joints, shutters, impeler, lower unit service, etc.)
Don S
Re: Gas in raw water pump oil reservoir
Yes it was, right up there with a 470.
Every fuel pump leaks a slight amount of fuel into the oil pan from a block mounted fuel pump. But it's a large space and never noticed. But Merc decided to put it into a 600 dollar housing so it would need replaced every couple years.
If your pump bearings are still good, put in new gear lube and make a cover to block it off.
Then install an electric fuel pump with the proper oil pressure switches and plumbing and never have to spend 1200 bucks again for a fuel and water pump change on a big block.
The proper marine fuel pump should be wired in like this.
PAUL22
Thanks don s.
I"ll look into that. Any suggestions on the pump and where i can get it?
Paul 22
