I have read many posts on props and know it is determined by RPM's, size of boat, weight of boat, particular motor. The boat is a 24 footer by 8 foot wide I believe. Its a bi toon. It has a 115hp mariner. I'm assuming the motor is a 1996 as well but do not know how to tell, anyone know where the information plate is or does it have one? I am not sure on the weight but it says 2900 pounds max for passengers and engine. So I'm assuming 2700 or so is how loaded I would have it. I have a lot of family. RPM's are a problem because it seems to start fine and at idle says like 2k, but when I give it just slight gas the rps skyrocket to 4 or 5k and at full throttle 9k or more. Not sure on exact because it maxes the RPM gauge. I don't think it could be this high or am I wrong? I'm assuming the tach is messed up. It currently has a 3 blade prop made by solas, I believe its a myth model and numbers say D3X13.75X13R. So does this sound like the correct prop or would a 4 blade pontoon prop be better suited? I know without correct RPM its hard to determine but is there any guideline for a 115HP mariner on a 24ft pontoon? Thanks for any help and if all else fails I could have the boat shop check rpm for me and then have you guys tell me the prop cause my boat shop don't know much.
