FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Would a 50hp motor work on a 24' pontoon? What size prop would it take? What are some guidelines to follow when
repowering an old pontooon? I guess I need a long shaft motor for this right? How long? thanks -jb
Yes a 50 will work with a good sound motor with a 4 blade pontoon prop depending on the weight,log size etc. you could expect a 18-20 mph speed with a light load.
If your running a fairly new Evinrude or Johnson 2 stroke a 12" or 13" prop should work.If the motor has a prop you could test with that and make a decission from that.Main problem with a 50 is at 20 mph it will be pushing its guts out.If you could afford a 75 or 90 you would have reserve speed/power for a load or a quick run to shelter. You could cruise at the 50s speed at 1/2 or 3/4 power of a 75 or 90
and the motor would be loafing. Of course you can cruise with the 50 as well but speed would be somethin like 15 or 16 mph.
I have a 24 ft Starcraft pontoon boat, I just got at the end of last summer so I only have had it out a few times. It has a 90 Hp Merc two stroke. What kind of speed should I expect out of it without hurting the engine. It's an 07 with very low hours on it.Most of the time it was on a boat lift before I bought it. How about RPM's. I used to have a 21 ft bow rider with a 230 hp I/O so speed and RPM's didn't matter that much. That baby would fly.
Hello, I have a 19' 08 Suntracker with a 40hp Merc Big Foot. The motor came with a 9 pitch cupped prop and the rpm read about 5800 WOT. I went to a 11 pitch uncupped prop and it dropped my rpm's down to about 48 hundred and put way to much strain on the motor. Went to the Black Max 14 x 10 extra cupped prop and that is just about perfect. hit about 5600 WOT and still get the bite I need while idling for docking. Love this pitch prop. Hope this helps.
I have a 1991 24' kayot with a 48 HP evinrude (1991). My GPS speed at WOT is 19 with light load. My cruise speed at about 3/4 throttle is 15-16 MPH. 13" prop. I can pull a 165lb adult on a knee board too.
My biggest complaint is noise, that 48 rude is a noisy motor.
Pontune,
I suggest you start a new thread. When you do, provide more info including number of logs, with or without strakes, estimated weight of the 8 people and gear, RPM at WOT, and any prop info you may know. It would also make a difference if you used GPS speed and had headwinds or a current in the water.
