myredchevys
- Apr 1, 2008
- 21
I am in the process of replacing my bellows on an alpha 1 gen. 1 outdrive. Reading the mercruiser manual step 1 it says to disconnect the water tube from the engine side and push it through the transom. After removing the bellows and bellhousing I was wondering if I had to remove it at all. Does it help in the reassembly? I wound up having to cut the hose at the engine side to remove it. Now that I have everything apart,the tube is sort of wiggling around in there-does it pull out thru the transom side with the grommet-seems like I am making more work for myself or am I missing something here? Thanks
