bigpikeguy
Thread starter- Joined
- Mar 30, 2010
- 9
Ok i have a 2009 G3 Eagle 165 with a yamaha F20 4-stroke powereing it. I am limited to the 20HP because In PA most of our lakes have a 20HP limit. I am so close to getting on plane its sickning. I started out with a 9 pitch alum prop from the dealer and that did not seem to cut the cake after it was broke in. So i swaped for an 8 pitch. that seemed to raise my RPM's but not really move me any faster. Then i bought a 8 pitch stainless prop that will get me on plain by myself but with 2 guys in the boat it wont. the thing is it will over rev once it gets on plane so i got to keep an eye on my tac so i dont blow up the motor. this is how close i am to getting on plane with 2 guys, if i run the boat in shallow water wide open with 2 guys in the boat it will get onto plane and start to over rev, but the minute i get into deeper water the rear end on the boat sinks back down again. im running about 10mph wiht 2 guys and once it gets on plain the speed climbs to about 15 i would say. my RPM's are at about 5400 sometimes 5500. Once i get on plain it wants to go over the recomended WOT of 6000. With a 9 alum by myself i had the boat planeing and running around 20mph with the speedometer, not sure how accurate they are lol. with that being said it really dogged with the 9 pitch wiht 2 guys hardly hitting 5000 rpm.
I already tried a foil on the back with no success. That worked on my other baot so i had high hopes. I was thinking of smart tabs but i really dont wanna drill if i dont need to. As of now i am in the process of moveing one of my batteries out of the back of the boat to front of the boat on the passenger side storage compartment in hopes that it will get some of the weight out of the rear. Right now i have 2 batteries and my fuel tank back there and i think that is why the rear end is sunk in the water at WOT. I dont fill my tank no more than 1/4 full due to the fact that i dont really need to since for one the 20hp is not hard on gas and i really dont need the extra weight. if that fix dont do the trick i dont know what will, im out of ideas. the fustrating part is how close it is to getting on plane. I think if this fix works i should be able to jump up to a 9 pitch stainless to fix the over reving problem and hopefully it will still get on plane??? i hope, but if not i will just have to keep an eye on my tac to make sure it stays below 6000 with the 8 pitch.
