mottt
- Aug 25, 2009
- 80
I want to make sure I am hooking this up correctly. Here are pics
1) is the kill switch. The 2 black wires are attached
I didn't want to spend the money for the actual ignition switch so a $8 one is going to do the trick.
3) Are the remaining wires that need to go somewhere. I know the two tan ones go to the solenoid. But where do they attach to the ignition?
4) Is the back of the ignition switch. There is a BAT, ACC, IGN and the center witch is the Start.
5) Another ignition switch
6) Ignition solenoid. What posts need to energized to make this work?... In other words how do you test this with a 12v to see if this is working?
This is one of my final steps in understanding the wiring system.
Any help would be appreciated
thanks in advance
thanks in advance
