oklahomariverfisherman
- Nov 11, 2009
- 70
This motor had been sitting for a few years, but it appeared hardly used before that. It took alot of pulling, but I got it started. I used the reccomended method of 3 minutes idle, 5 minutes lowest speed, 10 minutes middle speed. After this I revved it up a bit and had it running at higher rpms. It revved up a bit more on its own sputtered a couple times and died. Now it will only idle for the first few seconds when starting. After that it seems to only want to start when pulling, not using the elctric start. It will not idle. You must give it some throttle to keep it going. Sometimes the throttle will make it sound like it is burping, and it will die anyways. Sometimes it will accelerate almost normally. I pulled the carb off and cleaned it out. My repariman thinks the problem is in the carb. He lives an hour away and I prefer to fix this myself if I can. I would appreciate some advice.
