hunt-fish-camp
Thread starter- Joined
- Mar 22, 2010
- 2
My first post to this awesome site is a question about timing marks on a 1983 Chrysler 85hp. The flywheel does not have any marks only a number 10 stamped in it which does line up the the timing mark on the bracket when I check with the timing light. I am assuming the top cylinder is #1. If I put the cylinder at tdc can I make a mark on the flywheel and use that? Also when I was moving distributer it didn't seem to run better or worse, the idle would just go up or down. Is that normal? Also I just rebuilt the carbs and have them set at about 1 1/4 turn out and seems to run good. Is that to lean? I see other posts about running to lean and bad timing will burn a piston which I am trying to avoid. Sometimes when I turn the key to start I get a exhaust pop. Any info would be great. Kids are looking forward to a better boating season than last year.
