OMC 400 and 800 Lower units
Bigskybob
I have a 85 OMC 3.0 manual shift and i have to replace my lower unit, Got water in it and cracked over the winter, wondering if the 400 and 800 models are different. Or at a minimum are the housings the same. Thanks for any imput you might have.
Bob
Re: OMC 400 and 800 Lower units
Ayuh,... They're night, 'n day Different...
zbnutcase
Yup 800 is much larger than your 400, you will need to find a 400. 'nutcase
Bigskybob
Thanks, in pics they look real similair but i figured something had to be different. just have seen alot of 800's but only a few 400's none that appear to be in that great of shape.
Bigskybob
Another question, Found a good unit on internet last night(400) but it appears to be a little different, mine has an anode built in the upper part of the lower unit. The one I found has no anode, why and is their a difference between them.
Thanks Again
Bob
Howard Sterndrive
good eye. You do not want that one.
The rectangular anode is only found on 1982-1985 mechanical shift which uses a specific shift cable, shift converter box and ESA system on the engine ignition system..
1978-1981 were hydro-mechanical shift. The worst of the worst really, the hydro mechanism was prone to rust and failure if water ever got into the lower unit...and as you found out, that's not a rare occurrence in a lower unit.
Also the cable is different.
If you put your location in your profile, someone might recommend a local place to look for one.
Bigskybob
That would be great if someone could tell mewhere I might find a good used one, Don't really want to put rebuilt one on it, Hard to justify, spending that much on an older boat. Thanks
Bigskybob
I don't have a problem paying to have it shipped, used boat parts are few and far between in Montana.
Howard Sterndrive
yeah, until you hear the cost of shipping east to west. It's silly what they charge. North south shipping is cheap, but "horizontally" kills.
