trying to find carb kit for weber?
95VIP
does anyone know where to buy a rebuild kit for a 95 350 mag alpha 4-barrel weber carb.
also how hard is it to rebuild it myself?
Is it better to pay the 2 hundred bucks for someone to do it?
achris
More fish than mountain goat
Re: trying to find carb kit for weber?
$200!!! :eek::eek::eek:
I do those things in my sleep!!! A few screws and they are in bits on the bench. hose 'em out with cleaner and DRY compressed air, reassemble and you're good to go. 'Bout an hour if you have lunch in the middle.....
There is only on gasket on the carb, #27-809077. If you need anything else it will be the Acc pump...
Download the SERVICE MANUAL and follow the direction in the appropriate chapter.
Chris...........
95VIP
Thanks for the reply. i am having hell finding a rebuild kit. I have been reading other forums and sounds like the carb needs rebuild. Because it idles fine and runs great at WOT but between 1000 and 2000 rpm it fouls out the front two cylinders. Its a new motor.
achris
There is no 'rebuild kit'. There is only one gasket. If you need other parts you ordered them separately...
Chris........
Ayuh,... The Edlebrock Performer series is the Same exact carb,+ uses the Same exact parts...
zbnutcase
And wrong! There ARE more than one gasket in these, and Edelbrock has rebuild kits as does Sierra (18-7613-1) for these. 'nutcase
