fattypackard
Thread starter- Joined
- Jan 23, 2010
- 33
just got this boat for a good deal. boat is in great shape....motor, not so much...
its a 1981 Johnson 90hp V4
sounds good on the hose. idles perfect in the water. starts right up.
pushes the boat MAYBE 5 mph. no power at all.
did a compression check. i am assuming my gauge is accurate and i did the check correctly. based on that my readings were Top right cylinder - 60 psi....top left cylinder - 60 psi... bottom right cylinder - 90 psi...bottom left cylinder - 90 psi...
no i know thats not good. all 4 should be around 115, correct?
i spoke to the previous owner, he claims he's been running it and its a good motor. and the ignition packs may be bad. would the ignition packs cause such a big power loss?
also, something else i noticed is that when the motor is running, the bulb is NOT hard. it is soft and squishy. ideas?
should i start looking for rebuild parts....
or a different motor...
