1952 evinrude 7.5 hp #4443 pull start assembly
mr.ross
i cant find a pull start assembly for this motor. is there another year that would fit this model.
thanks for any info
bktheking
Re: 1952 evinrude 7.5 hp #4443 pull start assembly
thanks for any info
Post a want ad on www.aomci.org under the webvertize section, someone will have one for you.
mr.ross
will try there. so there isnt another assembly that would fit.
mr.ross
ok will try. so there isnt another assembly that will fit
bktheking
Quite possible, problem is being able to cross reference part numbers back from 1952. There is an ask a member part of the aomci site , many of the gents on the site, Garry for example, seem to have every parts list made. I needed one for my 55 5.5, just so happened a 54 fit but the seller knew it would, he contacted me from my posting on that site.
1946Zephyr
I believe 1950 and 1951 are the same as yours.:cool:
mr.ross
thanks. do you know of any other years. those will probably b hard to find also.
mr.ross
do you happen to know the part number for the assembly
mr.ross
i just need the rope and what it comes in. i have the cover,
thanks
1946Zephyr
1953 may also possibly work. I believe it was 54 when they redesigned the 7.5:cool:
F_R
1952-53 are the same. Earlier ones have a slightly different top housing.
Mr Ross, I have the parts you need. Send me a PM listing exactly how much of it you need. Include your e-mail address in the PM.
mr.ross
i need from the flywheel nut to the cover
thanks f r
