salmansaifali
Thread starter- Joined
- Mar 15, 2010
- 2
I just bought a 1999 Sea Pro Citation with inboard 3.0 mercruiser. The boat has approx 150 hours, and im the second owner. The boat is in pretty good condition and everything looks good. It was on a trailer when I went to look at it and had been winterized - we were able to put the ear muffs on and upon cranking, the battery was dead. with a portable jump starter, it started right up. a week later yesterday, i went to pick it up - we put it in the water, i notced the ignition was kind of weak but it started right up. I live 3 hours away, trailered it back, put it in the water, it cranked right up (although a weak crank) and i brought it to my slip which after running in the water about 20 mins.
When i tried to start it after about 2 hours, it would not crank. I knew the battery was dead so i went and bought a new battery today and installed it. Now, the cranking is good, the engine turns, lights, pumps work fine.
I used a multi-meter between the two battery terminals, and get full 12V.
This is my first boat and now very upsetting! I pumped the gas a couple of times before starting it - it cranks, sounds like it might want to start but just doesnt.
I tried again after an hour (I thought i may have flooded because I pumped the gas) - to no avail - cranks fine, but nothing else.
SUPER DEPRESSED!!! Please help!!!
