old_johnson
- Mar 15, 2010
- 3
I have this old johnson 115 from 1976 and just runs horrible. I have to get it started and slam it into gear in order for it to stay running and then it wont stay running at high speeds. It will bog and then if u choke it it will pick back up and then bog again until you let off the choke(and the cycle continues). I have gone through the carbs, coils, sync and link, adjustment of throttle and it isnt any of these things. So i pulled the carbs off and took the reeds out, they are rusty and some are a little bent. Could this be the problem?
