Coupler - GM 4 cyl. can they be rebuilt?
Jim Robbins
I have a coupler of a 140 HP Mercruiser GM and the aluminum splines are almost gone.
In this day and tech., does someone rebuild them?
elkhunter338
Master Chief Petty Officer
Re: Coupler - GM 4 cyl. can they be rebuilt?
I do not think you can buy rebuilt ones.
I have purchased two couplers for my GM 4 cylinder.
1st one was an old style, which unfortunately about 30 hrs later the engine failed from another issue.
2nd one was for the replacement engine I installed which was a newer engine with a different flywheel which took another coupler.
I found e-bay has some good deals on couplers.
Also consider replacing the input shaft if the splines also look worn. My first replacement was because the coupler failed and I needed to replace both coupler and splines.
EDIT: Not allowed on forums.
I have yet to see a rebuilt coupler for sale.
Bt Doctur
Couplers fail from mis-alignmment, period!!!!!
Engine stringers rotted, rear mounts bad,loose engine mounts,rotted transom flex.
HT32BSX115
Howdy,
In a word, No. You must replace it.
If you do it yourself, ensure that you align it properly using the correct tool or you will be replacing it again.
Regards.
Rick
Ayuh,.. Nobody Rebuilds throw-away parts...
It's a single use, Toss it part...
Jim Robbins
Just as I thought, replace with new. Thanks all
