name this lower outdrive...
89villain
let me know what you guys think this is. i feel like i got screwed. there is no drain hole on bottom of unit. thanks.
the numbers in pic are
1656
8865-c
SSSuper83
Re: name this lower outdrive...
Bravo?? Or Alpha Gen II??
89villain
thats what im wondering. heres hoping its a bravo 1!
SSSuper83
I'm just goin by the shape...doesn't sound like a Mercruiser #...If I am not mistaken..don't Bravos and Gen II's have different ways of draining gear lube? Just a thought...
Don S
How about if we name it Fred ?
Seriously, take a picture of it looking at the surface shown with the red arrows.
Right now, I don't think it's an IO lower.
attachment.php
SSSuper83
What did the seller tell you it was when you bought it?
Don S
I'll wait............
Just seen they said Bravo I, guess where the drain plug is at.
attachment.php
89villain
uploading pics to photobucket...thats were the drain plug is...behind prop. one on the boat is forward of the prop on bottom of drive.....damn slow a*s comp
Don S
Yes, that is a Bravo I. The earlier models had the drain plug on the outside of the drive, and assuming your screen name indicates the boat this is for, then it's the first year the Bravo's came out. (89).
SSSuper83
The one on the boat is on the bottom side of the lower unit?? Are you sure you don't have an Alpha drive on the boat now?? Just makin sure bud...
SSSuper83
Nevermind..late to post. Thanks Don S!
89villain
thanks don for the info. it makes me feel better, lol.
i just happened to look at it and i didnt see the drain plug.
so with this style do i have to fill the lower up with gear oil before i put the halves together?
and ss good luck with yours. i hope all turns out well. let everything dry out completly before hooking up any kind of power to it. drain the oil and replace cap and rotor while your at it. hopefully she will turn over without any problems.
thanks again guys,
brian
SSSuper83
Thanks 89..glad you got the right answer..def know you had a scare. Good luck. Yes..I am already makin the list..thanks for the condolences :)
Don S
You still fill the drive the same was as if the drain/fill was on the side. The nice thing about having the drain under the prop is it requires removing the prop to get at it. You then need to grease the prop. You would be amazed how may props I've CUT off and destroyed because no one ever took the prop off and greased the shaft. Then they corrode on and become one with the shaft.
The manufacturers should make all drives/lower units fill from behind the prop.
You have been up and visited the Adults only sticky at the top of this forum haven't you?
zbnutcase
I SO agree with you Don; I have gas-axed many props myself! 'nutcase
89villain
what will happen if i put a new style bravo 1 lower in place of the older style? it seems that i have a oil line that runs through the gimble to the outdrive.
brian
bump
