1984 Volvo Penta 2.3 carb problems HELP
Robbie5374
Re: 1984 Volvo Penta 2.3 carb problems HELP
Ok im downloading it now ill let you know what i find.
Robbie5374
I dont really know any thing about boats but i got it downloaded. Could some 1 please tell me if i should bend the float up or down?
captmello
The float height is a measurement. it goes both ways.
With a little patience, you could rebuild the carb in a couple hours. Take it apart, clean it, put it back together. You will need a rebuild kit which is available on Iboats.
Heres a sierra kit
http://www.iboats.com/mall/partfinder/?*******=682428404&gd_grid_id=855&gd_poid=112057&gd_row=10&**********=498050331
Read over the manual to get an Idea of it and follow the instructions.
Don S
DO NOT bend the float. If you do, then you must replace it.
There is no float adjustment on that carb. Obviously, if you have to push down on the float to get it to run, you have a problem with the float or the needle valve. Replace both and be done with it.
Robbie5374
Can you buy the float n needle valve seprate or do i need 2 buy the whole kit. Im just scared ill mess something up rebuilding it and ill have 2 take it some were.
captmello
The entire carb needs to get cleaned out.;)
The new kit might come with the needle valve.
Robbie5374
Does every 1 that reads this agree that what i need 2 do is replace the float n needed valve
Robbie5374
Im having a hard time finding the rebuild kit online can any 1 help
Robbie5374
I think thats it. Thanks
MTribe08
Ok, so you have 2 choices...buy a kit and attempt to rebuild it yourself with the possiblity you might have to take to somebody...or just take it to somebody and have them do it...Either way your boat is not going to run right until you do it.
Robbie5374
about how much does it cost to take it 2 some 1 and how long will it take me. im pretty good with doing work on cars but not great. is there any special tools? is this some thing the avg guy can do? it looks simple enuff im just not sure thats y im here askin. you guys have helped tons thanks alot.
Robbie5374
Edit:
rjwhite
rebuilding a carb is not all that dificult. just pay attention and readthe dir. price should be 20$ or so. it will fix any prob with float and needle. or just take it off and get someone to do it for you. around 150$
Don S
Not familiar with marine prices are you? The carb kit price for a Sierra aftermarket kit is $64. Doesn't include his bad float, or corroded carb, or whatever is actually causing the problem.
We haven't see the carbs inside, so how can you say what it's going to take to fix it. You also don't know where he lives or the going prices in his area.
captmello
I just reviewed the manual regarding rebuilding the carb. It has good step by step instructions.
Sounds to me, like the float has leaked, but we won't know until you tear it down.
When I've done carbs, I just lay the parts out in the order I remove them. If the carb was gone through 14 months ago, It shouldn't need a lot of cleaning and soaking. Makes it all that much easier. Just go through it now and be done with it.;)
If you're going to be an owner of an old boat, get used to working on the boat. Otherwise, pay up.
This carb job is just the beginning.:eek::rolleyes:
Robbie5374
do you guys happen 2 know the price of the float? what else do i need 2 get that doesnt come in the kit
Fishermark
Earlier you asked.....
How hard is it 2 rebuild the carb? Im pretty good with my hands ive just never done it b4.
I understand being nervous and making sure you are at least familiar with the basics before tackling it.... but come on! Eventually you are going to have to either try it or take it somewhere. The only way to find out what it costs it to ask the shop where you end up taking it. The only way to find out what the kit costs is to order it. The only way to find out what the float costs is to order it. When you get into it and run into a jamb, ask then. But at some point you need to DO. :rolleyes:
captmello
After looking at the online VP parts list. It appears you may need to buy one of several kits for rebuilding that carb. The float may come in one of the kits but it's hard to tell. In this link it shows two carb part numbers but the repair kits are the same.
http://www.volvopentastore.com/Fuel-system/dm/*******.951478187--**********.150315332--store_id.366--view_id.332568
I would suggest trying to find a dealer locally that knows the parts breakdown better and is familiar with the older Volvos.
Incidentally, you say your boat is has a 230 engine but your boat is much older. Are you aware of it being repowered prior to you getting it?
