steering
bd5580
I have 1985 ceria bayliner the steering is very hard there is no power steering does anyone have a fix or has added hydraulic to this type of boat it has inboard 350 with volvo leg.
livin4real
Re: steering
When was the last time the steering cable and helm was replaced? Outdrive pivots greased? I'd guess the cable and helm is original. I'd start there.
cr2k
Re: steering
unhook cable from back and see if it is stiff, then do so with the other end and see if helm is stiff.
5150abf
Re: steering
Welcome to iboats.
As stated unhook your cable and se how stiff it is, i think a new cable and some grease will fix this for you.
You can add Hydraulic but a base system is $1000, a cable and grease are WAY less than that.
