Re: lower unit leak?
I think that is normal , i have had that happen to mine but i dont use the earmuffs i use the inlet my motor has , if it leaks with my 90hp that way im sure its fine ....
Want to know if your lower unit is leaking , take out the small screw on the bottom of the lower unit , on the right side , there is one below the prop and one above it (you cant miss it), pull the one below a few turns and see what the oil looks like if it looks like water you have a leak ..... simple anough ..
