Using system check gauge
dc_1996
Hello to everyone
I just got my boat out and it turned over but did not start. So before I went any farther. I have the service manual so I did the system check gauge to enter the diagnostic mode. I have a Johnson 150 Fitch which I had the ECM rebuild by DFI tech so I have not had my boat out since. When I did the check 2 priority level A codes came back. code 15 which is ROM "check sum" verification and code 34 oil injector open circuit. So now I went and cleared the soft codes and I am recharging the bat. What do you guys think might be the problem and what to do next. Should I try after recharging with muffs and see if it turns
Thanks
Daivd
dc_1996
Re: Using system check gauge
Just checked my post this morning before I go out to fire my engine up and I saw that no one has replyed. This is where everyone has told me to go for advice.
Thank you
David
bob johnson
fitch is a whole system to its own and I bet few guys that know a lot about motors can say they know a lot about FITCH motors too!!
good luck
this is the place, but over night might be asking for an awful lot!!!!!!
bob
