ggou812
- Mar 6, 2010
- 3
I am attempting to change the water pump on my 1986 125 force motor,
(1251x6b),
and have removed the 7 bolts and the shift linkage pin. Seems to have come down just enough to see that the lower housing is free and not corroded to the upper half, and I have just enough of a crack to see that it did come down slightly, but now refuses to go further even with trying moderate tapping to the lu area. is it possible that the power shaft is frozen to the engine at the upper half? I have read that you reassemble with antiseize to the splines, but I have not had this motor in use before, purchased it used from an old friend and not sure if it the water pump has ever been changed until now, so possibly its going to give me grief coming off. This motor runs well, but has sat for 4 years and needs a little tlc before i test it in the water. Any ideas on what might help the shaft to break loose from the splines would be greatly appreciated. ona second question, Is the temperature sensor on the head (orange wire) on this motor a simple buzzer switch? if so, I may need to find a temp sending unit for my teleflex 50-200 Fairenhiet temp gauge, as the buzzer sending unit can't be complatible with my existing gauge.
(1251x6b),
