Re: 200 1998 oceanpro lost power
Motor turns clockwise, so TDC for #2 should be 60 degrees counterclockwise on the top of the flywheel from the mark for TDC for #1. And so on for the rest.
Yes firing order is 1-2-3-4-5-6.
Your suspicions are well founded.
If I could pester you a little more.
Does the firing mark go in order 1-2-3......
round the flywheel CCW?
What is the firing order?
