Hi
I have a Force 120 which I think is a 1995. The serial number is OEO97?95. The question mark replaces a damaged and unreadable digit on the serial number plate.
Could someone confirm that the engine is a 1995 please.
I want to replace or top up the gear oil on my engine however I am unsure as to the procedure.
I have a manual but I am still unsure what I should be doing.
The lower leg of the engine has three screws on the starboard side as listed below.
There are two screws in the casing situated slightly above propellor height. The one to the left has the word VENT embossed on the casing adjacent to the screw. This screw is positioned slightly higher than the one to the right of it which has the words OIL LEVEL embossed on the casing.
The third screw sits at the top of the skeg and has nothing embossed next to it.
All information will be greatly appreciated.
I have tried to upload a photograph of the engine but have been unsuccessful.
If you require a photograph I can email direct.
Thanks in anticipation of assistance.
