no spark just died like it was out of gas(switch box)
CharlieB
Re: no spark just died like it was out of gas(switch box)
Since there is NO RETURN on electrical parts, and they can get a bit pricey, it is important to test every component correctly to be sure to identify the bad component before spending your hard earned cash on unnecessary parts.
Do you have access to a DVA Meter ? Or search iboats for the instructions how to build your own DVA Adaptor to use with your analog Volt/Ohms Meter.
Download and study the FREE Ignition Troubleshooting Manual from cdielectronics.com
It is well written directions to guide you to testing each component of your ignition, step - by - step, to identify the bad component. Follow their directions TO THE LETTER.
If any further questions or problems repost and we can help direct you as needed.
RLT III
Well after waiting on parts after lots of testing to figure out and from help of you guys....a new switch box and she is running:D:D:D
Still waiting on rectifier and I'll be able to test her out
Thanks to every one here and all the help they give all of us beginners
turbinedoctor
Good to hear you got it running and thanks for posting your final results.
Durwood
