izoomie
Thread starter- Joined
- Oct 16, 2009
- 274
Hi All;
I have a 17' Prince craft with a 1988 90HP Johnson. The VRO pump was removed before I bought the boat.
I have two 6gal portable fuel tanks that I lift out of the boat to fill, and that is proving to be quite a pain. There is lot's of room to fit a 14" wide larger tank in storage compartments on both sides of the boat, but of course I will not be able to remove a tank this size to fill. There is the added mess of mixing the fuel.
Does anyone have a permanently install gas tank with mixed fuel, and how does that work for you?
Do you have to pre-mix the fuel and somehow transfer it?
How do you measure the mix, if the tank is partially full?
