bravo 1 outdrive question...
89villain
im looking at buying an outdrive on ebay and im wondering if there is a difference in the outdrive shafts between a 7.4L 454 and a 5.0/5.7L ?
i dont want to make the mistake of buying something off of ebay at around $2500+/- and not be able to get the shaft into the motor.
thanks,
brian
Don S
Re: bravo 1 outdrive question...
The shafts are the same (for the most part) unless it's a fairly new drive. Serial numbers are needed to verify what you are looking at though.
Have a look at this thread.
Oops, forgot the link http://forums.iboats.com/showthread.php?t=375398
89villain
unfortunatly i dont have the serial numbers on hand, but i was told i had the old style bravo 1 on my boat. i just bought it and it has a bad propshaft. my mechanic is telling me its gonna cost around $1200, so i was thinking of just replacing the whole outdrive. are the drive shafts different from old style to the new style?
thanks,
brian
i didnt see the link that you tried to post.
Don S
Outdrives have 3 shafts, input, vertical, and prop shaft. Which one are you asking about.
Recheck for the link.
jtybt
Except for some upgrades in case design, all bravo upper cases are the same. Why not just buy the bravo I lower. You have to match gearing but generally, the BI is 1.5:1
89villain
thanks guys for the help! i think i was referring to the input shaft as in if they are all the same spline count and diameter that goes into the motor.? i found a place near me that has an outdrive for cheap and will install it for me. i think i got a hell of a deal(1500) installed!
thanks again,
brian
Ayuh,... All the same...
