Wishiniwuzfishin
Thread starter- Joined
- Jan 17, 2010
- 415
I took the battery out of my boat and brought it inside my house when I winterized the boat last fall. I just checked the battery and it has an approximate 75% charge according to my hydrometer. The label on the battery reads:
620 MCA (marine cranking amps)
400 CCA (cold cranking amps)
80 Ampere hours
200 load test amps
My battery charger is a 30-40 year old 6 amp charger and I don't know if it is automatic or not. So I want to check it with the hydro again to make sure it doesn't overcharge. I was just wondering how long I need to charge @ 6 amps to get back to full charge. I'm figuring I need to put 20 amps in it (the 25% I need to get to 100 % charge=25% of 80=20amps). So I need to charge at 6 amps approx 3 1/2 hours. Correct?
80 Ampere hours
200 load test amps
