fuel pump
redfish1940
on a 200 hp ocean runner. When I start the motor after squeezing the primer bulb. it quits running After the fuel runs ot of the carbs.. I disconected the fuel line coming out of the vro. and crank it over without the motor running. and no fuel squrts out.
is it a bad vro or does the engin need to be running for it to work.
thanks
Re: fuel pump
The OMS pump runs on crankcase pulses. If the motor is cranking, it should be mixing oil with the gasoline and pumping the moxed fuel to the carbs.
redfish1940
Re: fuel pump
Thanks
I thought it should pump out fuel with just cranking . Even though the motor is not running I will try to rebuild it. I think Iboats has a rebuild kit.
thanks again
tashasdaddy
Re: fuel pump
what year and model 200, verify so we know if it is OMS or VRO. if Vro 1 or 2, replace with OMS pump.
daselbee
Re: fuel pump
I had the exact same thing happening to one of my 200s. Exact.
I obviously could keep it running by pumping the primer bulb.
I found that the torx head screws on the BACK side of the pump, (the air motor side), were slightly loose. Tighten the screws 1/8 turn past the contact point, evenly so you don't warp the housing, and see if it fixes it.
Worth a shot before you rebuild. Free.
When you start it, you should hear the pump click regularly at idle. Maybe every 10 - 15 secs. If it is not clicking, air motor is likely at fault.
redfish1940
Re: fuel pump
Its a 2001
Im not sure if it clicks the motor is loud and my hearing is low.
It did leak at the pump when I squeezed the bulb, I put a new oring in and it quit.Its not leaking now when the bulb is hard
thanks
daselbee
Re: fuel pump
Its a 2001
thanks
Huh? 2001....Must be a Johnson then. And yes, it is hard to hear the clicks. But, it is a VERY GOOD way to determine fuel pump functioning. If it clicks, and no fuel, the fuel side is suspect. If it doesn't click at all, the air motor side is suspect. Every time it clicks, you should get a shot of fuel from the output to the carbs.
What o-ring? At the fuel inlet nipple?
redfish1940
Re: fuel pump
It was a 2/12" oring pump side I think. Had to remove the tork screws. The only place to find that size oring is at a hydrolic pump shop .50 cents.
It is a johnson.
Thanks
redfish1940
Re: fuel pump
Update
I think we got it working .wont know untill i put in the water. I rebuilt the pump. but I think it might have been that housing leak.not sure.
Thanks for you all's help.
