pulse limiter 1989 Johnson 200
chefboyrdjr
anyone know how to test the pulse limiter? got it out ... should you be able to blow air through it both ways? How does the internal valve work?
ezeke
Re: pulse limiter 1989 Johnson 200
When the pressure is too great, as with a backfire, the valve closes.
If the pulse limiter is black, it should be replaced with blue and gold.
If the pulse limiter is fouled, it needs to be cleaned; isopropyl alcohol will do.
chefboyrdjr
so you should be able to blow through it both ways?
ezeke
Normally, air will pass through both ways. When the air speed from the engine is too great, the valve will close.
