jay_merrill
- Dec 5, 2007
- 5,653
Re: Planes - Bears- and Duct Tape
From what I can see, its really the horizontal stabilizer on the right side that is torn up, not the elevator. Although it looks like it may have been bent down somewhat, its hard to be sure from a photograph. What I would have done with it, is to wrap the tape, such that the end faced aft. That would keep it from peeling back.
A piper cub is a slow, very docile aircraft. While the damage looks almost catastrophic, it really isn't, because most of it was to the fuselage. As long as the airfoils and control surfaces are properly functional, you could fly the airplane with no covering on most of it.
Also, look up some history on battle damaged B17s, from the WW2 era. They are much bigger airplanes, but have been compared to Piper Cubs over and over. They reason why, is that they are slow and docile, as far as bombers go. They are also very easy to fly, other than the complexity of having 4 engines, etc. Those airplanes used to return after bombing runs with huge amounts of damage, on a regular basis.
Here's one that is missing the entire port tailplane - it returned from a bombing run and landed successfully.
