threedogs333
Thread starter- Joined
- Feb 20, 2010
- 15
Hey, everybody first post so here i go. I have just installed a Johnson 115hp 1994 on my boat and need to know if there is a steering tension device located on the motor, as it is very stiff to turn, my 90hp that came off the boat was very easy to turn so i know it is not the steering at fault. I have tried to pump grease in but it can't or won't go into the shaft, unscrewed the grease nipple and that's not blocked. does the motor have to turned to a certain point or should the motor be turned whilst pumping grease in.
