pointandshoot
Thread starter- Joined
- Feb 23, 2010
- 22
hi all, i've been lurking on the forums for a while...LOTS of great info on here. i've got a few questions about a mercury 9.8 i bought from a co-worker with serial #715XXX. the motor starts and runs ok (even tho it takes a lot of pulls) and will idle all day long, but as soon as i try to apply the throttle it bogs and cuts out. i've taken the carb apart and cleaned it, everything looks fine (fuel pump and gaskets etc...), and the idle mixture screw is turned 2 full turns from seated but i'm not sure what the factory settings are supposed to be. also another thing that i am not sure of is the routing of my crankcase vent line. most of the pics that i have seen on the net show the crank vent line going back to the exhaust port cover, however mine comes forward and taps into the carb (is this right?). any help would really get me moving along and thanks in advance.
Craig
Craig
