1987 225 johnson
neader
Hi: I have a 1987 225 Johnson that has the first three piston's
at 75 psi compression then two @ 70 psi and one at 68 psi the engine is running pretty good but I'am a bit worried about the low compression?
Could someone give me
some info, :confused:
Madfisherman
Re: 1987 225 johnson
Agreed they are low, but fairly even. Have you tried a de-carb on it?
Faztbullet
It could be you have a tester that reads low, try the decarbon as suggested..
ezeke
Those readings are too close together; are you testing with all the plugs out? Is the engine warm? Is the engine properly lubricated? Are you using a screw-in tester?
neader
Yes all the plugs are out and the engine is cold and I'am using a old
screw in tester. Should I run the engine first then test it's compression ?
P.S I haven't used the sea foam yet
