newbie questions. quick answers :)
ezmobee
Re: newbie questions. quick answers :)
For starters....even if that motor is blown, there's over $500 worth of stuff there.
If the motor has good compression, everything else if fixable. It may indeed be as simple as a carb cleaning and some new plugs.
clarkbre
If you go to look at it and the engine runs, $500 would be a great price. Even if it didn?t run, the boat and trailer look to be in fairly good shape.
As far as a tune up for that engine: (if it runs)
Clean the carb
Change the sparkplugs and gap properly for the engine
Change out the lower gear oil
kriegersa
really? do you think i could put a platform on the front? and how does that trailer look? i really dont have any idea what to look for when making my first purchase. lol.
kriegersa
how would i have to clean the carb?
clarkbre
Ok, I?ll tell you the process I?d take it through. Whether it be $500 or $5,000, all used boats should be checked for this stuff:
Trailer:
Check bearings for proper grease and maintenance repack or replace if needed
Check tires for cracks, wear, rot, flat spots, and replace if needed
Make sure all bolts are tight on trailer so nothing fails from being loose
Repair all electrical so that the lights work perfectly, you can get a new trailer wiring kit with lights and wiring for about $50
Boat:
Check for any leaks and fix immediately
Engine:
Check compression
Clean carb
Change plugs
Change lower gear oil
Use fresh gas
You could put a platform on the boat if your really want to. For a boat like that, I?d probably put my money elsewhere. If you do go the platform route, make sure the boat is stable. From the pics, it looks like it?s pretty long and narrow. I?d be concerned about raising the center of gravity.
What were you thinking for a platform? Did you want to mount a pedestal seat? Or would you make a deck the same height as the bench seats and put storage under it?
Another thing I noticed from those pics was the engine height. For best performance, that outboard would need to be raised about 5?. The cavitation plate should be about level with the bottom of the boat. It will still run fine but it?s just more engine in the water that creates more drag.
ezmobee
Tough to tell from the angle of the picture but clarkbre could be right about the motor height. Maybe a long shaft motor on a short transom. However, you really need a photo taken from the level of the boat's keep to really be able to tell. That boat would sell in 1 day at that price in my area.
My dad bought a similar boat (not quite as nice) with a fairly crummy 1 cylinder 5HP Mercury the end of last season for $650.
kriegersa
Trailer:
Boat:
Engine:
Check compression
Clean carb
Change plugs
Use fresh gas
For the platform i was thinking about putting it all the way to the lip. I've been doing some research and i want a stable platform boat, i wont be taking it out on the ocean but maybe on some larger lakes, but mostly rivers and water like that. so i would rather sacrifice some moving stability for some standing stability, if that makes any sense. but what im thinking about doing is saving up a little more money and buy me a good flatbottom boat with a few other goodies and use that one :)
wow, yeah this one is located in north alabama if you want it :p i think ill pass on this boat because like i said up there i want to put a little more money in to something that i know i wont regret. but thanks for all your help guys :)
-kriegersa
mitchell6
what part of Alabama you live in I have a lot in Centre Al. and i have a uhaul tow package that bolts to a s10 that you can have to get it out of my way if your close enough that you want to get it
kriegersa
i live in madison 35758.
