I've done some research on this and as usual, I've gotten myself confused. I've attached some pictures of my boat. The main battery is in the usual location on the port side under the sunpad. It is currently wired so all house power except the 12V fridge runs off of it. In the little kitchen area is another battery and its own charger. It is dedicated only to the 12V fridge. This seems like a waste. My optimal setup would be to move all house functions to the second battery in the kitchen area on the starboard and keep the 12V fridge there as well. To accomplish this, I plan to add the Blue Sea Systems "Add A Battery" kit.
http://www.overtons.com/modperl/pro...Circuit_System&str=add+a+battery&merchID=4005
I'm assuming this will allow me to safely isolate the starter battery from the house current draw while anchored but when underway, allow the boats alternator (Honda BF225) to charge both batteries.
Then to make things more complicated, I'd like to maintain the ability to keep the charger. The cheapest option would be to keep the current 10amp charger. Is it possible to use it to charge both batteries with the Perko switch in "combine" mode? Or do I just leave the current charger attached to the house battery and buy another battery charger for the port side? Or should I buy a dual bank charger?
Thanks for any input.
