I'm reworking the front yard and need to pour 2 small concrete pads next to the driveway. The first pad is 2'x18' and the other is 2.25'x22'. I've done some research and it doesn't seem too terribly difficult, just back breaking work.
I'm planning to use premixed concrete (Quikrete 1101) and pouring 4" thick pads with expansion joints every 8', like the existing driveway. Couple of questions:
- Do I need to use reinforcement, 6x6 wire mesh or rebar? (I think so)
- Should I add additional cement to the Quikrete, say 5# per 90# bag? (I've heard Quikrete has the minimum amount of cement, IE: it could use more cement)
- I'm going to use 1/2" asphalt expansion joints where the new pads butt up against the existing driveway and sidewalk, they are needed,,, correct?
- Am I crazy thinking I can mix 18-25 90# bags of concrete in a wheelbarrow without problems, should I look into renting a cement mixer, size? (I won't be the only one mixing and doing 1 pad a day)
- How many 90# bags of cement can I mix in a 6 cuft wheelbarrow or 6 cuft cement mixer? (I'm thinking 1)
BTW, I was thinking of having a ready-mix truck deliver it until I spoke top one of my neighbors. He said it was $300-400 to have a short load delivered...
Thanks,
fishrdan
Thanks,
fishrdan
