Re: I/O vs Outboard, which should I choose
Ok let me see if I can get both in one response.
smokeonthewater:
I was thinking of using mainly just the block from the truck and switching everything over from the cracked block out of the boat. That is of course, assuming the parts are still good and the tolerences, clearances, and such are all within limits to switch things over. Of course I would still need to purchase a gasket set, starter, and alternator and this wont help with the exhaust manifolds but it will drop my costs a little. Also, since I do all my own machine work, I will also save money there as well.
jkust:
Yes the force has been reliable for us so far but we purchased the boat in running condition with a lake test before purchase so we knew it was already in good condition. After around 12-15 hours or so of owning the boat with the Force engine we lost a CDI pack. As I said before, I am sure this was because of age so it was no big deal. Other than that, I have found the Force is easy to work on, and everything is easy to get to. Its a big engine with a pretty hefty weight to it but since it is the first I have personally owned in the 125hp range Im not sure if it is heavier than others or if they are all around the same. I have however found that another brand such as Mercury, Johnson/Evinrude, as well as a few others would have the same power at around 90hp as this one at 125hp. Not that big of a deal to us since we are out for the fun and not so much the speed but if the time comes up for a new outboard then I will be looking for a little more speed and better fuel economy. However, I cant complain on the fuel as we only used around 9 gallons so far since we purchased the boat so it appears to be pretty good on fuel. It is definately better on fuel than our pontoon with 48hp Johnson. There is an island we like to go to when we go camping. From our campsite the pontoon uses 11 gallons of fuel to get there and get back, it only has a 12 gallon tank so we also take a gas can with us. The Maxum with 125hp Force only uses 4 gallons roundtrip.
