What Is It? From 1964 Lark 40hp
lindy46
Hopefully this will be my last question on this motor. When I got the motor, the transom clamp was not attached to the motor. As I was re-installing the clamp assembly, this spring fell out from somewhere. Any idea what it is and where it goes? It is painted blue so it must be an external part.
bktheking
Re: What Is It? From 1964 Lark 40hp
This is only a guess, it might be the spring at the back of the starter assembly for the part called the "bail".
rolmops
That spring would be part #306265.
It keeps the tension on the arm(#303863) that releases the lock on the swivel bracket(#377532)
KB1
Just read all of this and that was going to be my assessment. The spring for the lock/unlock to tilt.
F_R
rolmops gets the gold star, that is what it is. It's main function is to keep the lock/release lever from vibrating and making a bunch of noise.
