1978 Johnson 85 Horsepower Motor Tilt
DONNABOMB
HELLO I HAVE A 1978 JOHNSON 85 HORSEPOWER OUTBOARD ON A BONITO BOAT AND I NEED TO KNOW HOW I INSTALL HYDRAULIC FLUID IN TILT?:confused:
emdsapmgr
Re: 1978 Johnson 85 Horsepower Motor Tilt
In 1978, OMC made a combination trim/tilt system which mounted inside the two transom brackets. There is a reservoir on the starboard side of the system which has a screw midway up the side. You fill this reservoir up to the lip of the screw hole. Run the system up and down a few times, then add more fluid. It will self-bleed by doing this up/down cycling. Keep adding till the system stays at the full level.
ezeke
Be sure to support the motor with the trail lock when adding fluid.
DONNABOMB
thank you so much for your help!:)
86 century
Ensign
Number 30
