galvanize or paint?
tbird175
I have a very well built trailer under my 17' bowrider that was built with galvanized steel. The tongue is 3" pipe and the frame is 4" channel, It is a tilt up design. Someone painted the galvanized steel with black paint. As usual the paint is fleaking off. Should I repaint or try to remove the remainder of the paint? How could I remove the paint without damaging the galvanizing? By the way it is at least 40 years old but the galvanizing where exposed looks good.
john from md
Re: galvanize or paint?
In that case, I would go ahead and paint it. Scub it down well with a good cleaner and a scotch brite pad, prime with a good automotive primer and paint. It will probably last another forty years. (if the axle is good)
As to removing paint, chemical paint removers won't take off the galvenizing as it is a hot dip process. Most paint removers now are pretty tame and require alot of mechanical scraping. Use scotch brite rotary pads and wash them out frequently in mineral spirits and they will last longer.
John
Tainted Halo
what i would not use is an automotive primer, reason is Galvanized gives off a chemical reaction with air, regular automotive primers will create air pockets under the paint and over time will chip. after fixing many railings and docks etc this is what i would do,
Clean off all the paint Scotch brite if it's flat use 400 or even 200 sandpaper and get it all off...make sure you hit every surface, the corners are the most important, but make sure you don't hit bare metal... once it's clean use a good cleaner that does not leave residue Napa has a variety, or u can use alcohol ( but it's not cheap) once she is clean you start your paint ......use an metal pro (Napa) Acrylic primer for Galvanized steel Napa part # 5050 if your going to spray it cover everything around you it's sprays as a very fine mist very fine dry to the touch in 20-40 min ... cure time 24 hours. this will seal any pockets where oxidization could occur, after that us the metal pro color paint or Tremclad simple it's the most cost effective way to paint metal, If your going with a custom paint job then on top of the acrylic use good paint and your golden.... i have pipes that out in Salt water and have been for 10 years with lights in them and there are no issues to date.... if you have any spots afterwards that you want to smooth and or fill use Sica 10lm caulking the stuff will never peel off and can give those hard to reach corners that nice finishing touch..
