Ocean31@bellsouth.net
Thread starter- Joined
- Jan 16, 2010
- 39
I am the new owner of a 69 Katama class Boston Whaler. One of the first things I did was install a Attwood fuel water separator from Walmart. I had a problem when I first purchased the boat with water in the fuel tank. I pulled the tank, emptied all the fuel, cleaned the insides and even used a small hand pump to get the last little bit out.
After getting all the problems with the engine worked out. I got a chance to take her to the lake and run the engine. I found the fuel primer bulb collapses and the engine quits from lack of fuel. Wait a minute or two and the primer bulb will pull fuel from the tank.
Now what I have done is checked, and or replaced all the hoses, fuel fittings, and so on. No air leaks and no restrictions. I started at the stiff plastic hose inside of the fuel tank and went all the way to the engine. I installed new primer bulb, end fittings and so on?..
I am running a Tempo 12 gallon plastic tank installed under the seat platform. I have the fuel water separator installed on the port side of the platform attached to the bottom edge of the platform thru bolted into the wood that runs along the bottom of the platform. This leaves the actual canister about three inches above the top of the fuel tank. From there it goes about 20 inches, then the primer bulb, and then finishes up at the engine. I am running 5/8 hose throughout, and I have a 115 1973 Evinrude.
So my question(s) are??
Should I have installed the filter canister below the tank top?
Should I have installed the filter canister after the primer bulb?
Is it the filter itself? I only have about 30 minutes on this canister, mostly on land with a garden hose, fixing the engine. But I know Attwood has had some quality control issues, so should I go get another canister, maybe change to a Sierra canister?
Any thoughts? I have found this forum is a outstanding place to find a answer.
THanks
Ocean
THanks
Ocean
