fuel mixture 1964
circle hook
what is the fuel mixture for a 1964 18HP Evinrude the book I believe says a 30weight motor oil, but can I use my 50:1 pre mix that I have for all my other engines, that is gas and 2 stroke oil. Thanks Bob
MudLake
Re: fuel mixture 1964
I think 50:1 is too lean for that age of engine.
I posted the same question about using 32:1 and was informed that maybe 32:1 is too lean.
Therfore i am going back to 25:1 as to the info that all the people on this site have suggested.
My outboards are a pair of 1961 Johnson 18 HP
cheer
kbait
I think the '64 and newer motors took 50/1. Someone will chime in on this.
bktheking
It's 50:1, 64 was the first year they went with that mixture but there is nothing stopping you from running more oil in it, 40:1 will work too.
Woodonglass
My Manual for 30-40 hp Evinrudes 1956-64 models says a 24:1 mix use Outboard Motor Oil or a Type MM-SAE-30 may be substituted.
Woodonglass
If you send me a private email I will send you the PDF file for the entire Manual.
ezeke
Not necessary - the clip in your thumbnail says "before 1964", which is what I expected.
F_R
Hey wooden, that picture you just posted says 1/6 pint per gallon (50:1) for 1964.
circle hook
so guys I guess 50:1 of TWC3 will work with no problem in my 18HP 1964 Evinrude or do I need that MM 30 wieght @ 50:1 Thanks Bob
Woodonglass
Well, you guys are as bad as my wife, always pointing out my mistakes!!!! LOL :p I stand CORRECTED!!!!! AGAIN!!!!!!!!!! 50:1 it is. I CAN read, just not as good as I used. to. Oh well you can't be right all the time, you're wife would'nt have anything to complain about. Thanks for the CATCH!
