Re: Mercury HELP!!!!!!!!!!!!!!!!!
Classic symptoms of a too lean idle mixture.
You're used to cars, adjusting idle to best idle. That's not quite like a 2 stroke.
The 2 stroke does not have an accelerator pump, so the idle MUST BE RICHER to provide the additional fuel for acceleration.
While ON-THE-WATER and in FORWARD GEAR, adjust the idle mixture to best idle speed PLUS almost another 1/8 turn out.
Test by slamming the throttle control to WOT, ANY hesitation, bog, or lean cough, fatten the mixture just another width of the screwdriver slot.
Repeat acceleration test, adjust to perfection.
On the hose you may have to turn out about 1/4 turn, but on the water is the most accurate method.
Edit:
Running an oil rich mixture on a fresh motor, the idle adjustment should be done again once the motor is broken-in and the oil mixture is returned to normal 50:1
