bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
the motor is a 2001 50 hp johnson 2 stroke, VRO disconnected. premix gas.
I sold the motor to my buddy, it always ran great...I borrowed his boat and had issues.
He didnt install a fuel filter like i suggested, nor a water seperator.
the motor was running great , then on a quick shutdown to look at something off in the distance....the motor bogged when trying to go again..
it sputtered a little and them went right back to running fine..
went a mile or so and throttled down to watch for rocks.. and the motor sputtered and would not rev on the throttle up again.
then i noticed the gas tank was almost empty...I figured it was either no gas or some junk in the bottom of the tank stuck in a carb..i switched out tanks..a tank i brought from my boat..
motor still would not rev, most i could do was about 6 mph..
when it normally can do about 30 mph.
limped in.
played with the plugs... idles fine..revs in nuetral good.. sounds OK...
at home i put on the muffs and played with the motor... switched plugs...same thing
checked the spark...with a spark tester.. both cylinders are getting good spark( looks the same in daylight!) jumps about 3/8th no issues...
when running if i remove the top plug wire you hear a noticable rpm drop...it sputters once in a while but stays running.
put it back on and take the lower plug wire off....it drops rpms more noticable than the other, but it still runs...it SEEMS to sputter a little more and once in a while sounds like it may stall...but it doesnt( actually it did once in 5 tries)
so it sounds like I have more combustion in the lower than the upper.
ok, Ill do a compression check soon...BUT
it was running strong!! till i throttled down quickly and till i got to the bottom of a dirty gas tank...both maybe coincidences...dont know yet...
I poured all the gas left into clear bottles and found a little debris from inside the tank!!!!
so question:
I know a clogged carb is one possibility....but can the power pack give me a seemingly nice spark at idle, but not be up to the task at higher rpms????
it has no power under load...
it revs good..
both spark plugs looked ok, one slightly oilier than the other...suspect cylinder a little darker...
thanks
bob
limped in.
so question:
it revs good..
thanks
bob
