JGra
- Apr 24, 2009
- 222
I have been putting and old boat back together since about the middle of the last summer. I have most of it done and took it out for a sea trial right before it started to get cold. I really did not winterise it other than adding some sea foam as I planned on using it over the winter. After all its not normally this cold in the south. Anyway I cranked up the motor today (try to do it at least once every 2 weeks) to run it for awhile. Motor cranked right up and ran real good. Had a good stream of water out of the tell tale. After doing alot of reading on this board about the importance of having a water pressure gauge. I had bought a water pressure gauge about a month ago and since it was a decent day I decided to install it. It was a simple job to do. I just tee'd into the tell tale and ran the line up to the gauge. My question is the pressure. I only seem to be getting 2-3 psi sitting there at idle. Now granted I am running on the muffs. Once I bring the idle up (not too high) I can get it up to about 4 psi running at no more than 1500 rpms (again I am on the muffs). I know from what I have read this is kinda low but it seems to have a great stream. I double checked the line for kinks and all is good. Am I not getting a good reading because of running on the muffs. This is a new to me 89 90 3 cyl mercury that I had bought middle of the summer. I was told water pump was replaced first part of the summer (so thay say). Should I put it in the water and run it first before installing a new water pump. Could use some advise. Thanks
