1985? cross flow or looper
sred137
My question is I have a 140 hp v4.Should this motor have the year of the motor in the serial number?
The title says the motor is a 1985.This I think is a cross flow motor but the manual says that the cross flow motors have the thermostats in the exhaust housing.If the thermostat is in the their would I still have a temp sensor wire running into the cylinder head?
I just want to make sure that I'm not mistaken in the year and make of my motor.The model number is J140TLCO.Also If anyone could tell me what the letters mean in the model # that would be great.
I ask about the serial # because their is an 86 in it is this just coincedence?
Thanks for all your help
Shawn
daselbee
Re: 1985? cross flow or looper
1985 140 is a looper.
Look your motor up on the wiseco.com site.
J= Johnson
140= HP
T= Trim and Tilt
L= 20" shaft
CO= 85, C=8 and O=5
The 86 in your serial number is coincidence.
ezmobee
The wire going into the cylinder head is for the overheat sensor.
sred137
http://www.iboats.com/mall/partfind...23&gd_poid=111072&gd_row=52&**********=829601
Will this kit work for my motor.What is confusing me is that in my manual the exploded view for the crossflow looks like the parts pictured in this kit.
The way I read the manual is that the thermostat is mounted in the head.The gaskets in the kit would not work.Am I missing something?
What years did they make the crossflows vs. the loop charged motors?
Thanks for the help?
Faztbullet
Omc made 140 crossflow from 1977-1984 the in 1985-87 it went to a small bore looper. When customers call me and ask how to tell between the two I tell them: If it has a hose off bottom of heads similar to a letter "S" and size of middle finger ,its a crossflow. No hose its a looper.
sred137
So the kit in the link above says that it will fit 78-85.Then it should not matter if it is a cross flow or a looper?The manual gives different instructions for maintenance between the two.
Or does the same parts go in different places?
Sorry for asking so many questions but the manual is very vauge on this subject.
daselbee
Go to shop.evinrude.com, look up your motor, and according to the diagrams, your thermostats are in the top of the heads, one on each side.
The kit you are picturing is for the thermos that are mounted down low on the back of the engine at or near the powerhead to adapter plate joint.
I believe the Sierra kit you have pictured is the wrong part.
sred137
I agree thanks and I will go to the web site you mentioned.That part kit looks like it should be thru 1984
sred137
Thanks again for all the help.I looked on evinrudes website at the exploded view of my motor and got the correct part #.Again thanks.All my questions have been answered.
kenmyfam
Great stuff. Enjoy your looper, we love ours.
sred137
Will do.These motors are great.I bought the motor used and put it on a 1972 starcraft holiday 18 foot boat and it really sings.I just need to get some of the bugs worked out.I will be doing your fuel pump conversion,changing t-stats and rebuilding the carbs this off season.I should be good for the spring walleye jig bite on lake erie.
Shawn
ezmobee
Make sure you make your way down to the Starcraft section on this forum. You've stumbled upon probably the largest hotbed of Starcraft enthusiasts on the 'net! We like pictures :)
sred137
I have just stumbled across your links.That is awesome.I will surely post up some pics of my boat.And I love to to look at the pics of the other boats.The get together you have planned sounds awesome although a bit of a haul for me it sounds like a great time.
If you guys ever decide to move the event north I would be in for sure.The Lake erie islands and Put in bay is always a great time in the summer.
Thanks again and I will post up some pics on the starcraft thread
kenmyfam
So where are you located ???
