JSGOLD
- Sep 22, 2009
- 609
Do any of you run kicker motors and if you do is it a big deal for the kicker motor to be in the water the same time as the bigger motor? I am still trying to plan my Starcraft additon when spring gets here and am trying to figure the best thing to do. What I hope to do....have a 55hp main outboard that is used ONLY in larger lakes, say 30% of the time, and a 61- evinrude 5.5 as a kicker / trolling motor in smaller lakes most of the time, Since steering with the tiller will be difficult I am planning to add a second speed control (have that now) but I want to steer both up front as well and I wonder if hooking up the steering rods will be difficult with the kicker motor on a mounting bracket, as I have seen some do. The smaller motor has no tilt and neither does the big one, however the big one I can get propped up before going to the small lakes. Bottom line.....what is the BEST way to hook up and use a small motor like this on a 16' boat? I have the connector from Iboats to tie motors together....would the small motor cause a drag on the 55 in the down position? Anyone got any pics on theirs done this way?
