ckgreenman
Thread starter- Joined
- Dec 6, 2009
- 74
Re: What to do next?
No. The information is from a local boat mechanic (who initially found the low compression) and a local race shop mechanic (who is the guy I took my heads to at the recommendation of the boat mechanic). The very first mechanic (the one who did the engine swap) is the one who should have found the fuel problem and the one who should have talked me into a new motor. But if the info I'm getting from my current guys is wrong then I don't know what the right course of action is. Do I have one of them rebuild my engine? I know my way around an engine but I don't consider myself a mechanic however I do have a lot more knowledge.
I take it your "Information from Mercriser" was your dealer, kind of figured that. A "Real" Merc dealer would have never wanted to install an aftermarket rebuild in your boat to begin with. He would have told you the problems with the rebuilders and would have tried to talk you out of it. But would have used an aftermarket if you insisted. But he probably wouldn't have suggested one, because that would have made him responsible if it failed.
Personally have run into several aftermarket engine rebuilders that put out really junk engines. Good news is that I have never heard them mentioned on this forum.
You can do it yourself, but you better be a mechanic and understand what you are doing and what to look for. There is a lot more to it than just putting parts together.
