6 amp stator
lindsey
I have a 1973 85 rude it didn't have power t&t to make along story short i took a power trim unit from a 1979 115 rude.I had some bushings made and that took care of that issue. So heres the ? The 85hp has a 6amp stator the 115hp had a 10amp stator will there be any issues with the charging system using the power t&t with the 6amp stator?
Dhadley
Re: 6 amp stator
Depends on how much you use the trim and how much other stuff is drawing on the battery. Under normal circumstances I doubt you'd have an issue as long as you have (at least) a 1000 apm hr Marine battery and everything is working as it should.
